    • Avnet Boards Community
MiniZed Hardware Design MiniZed JTAG FTDI FT2232 Programming (FT_PROG)
  • Subscribers 322 subscribers
  • Views 680 views
  • minized
bhfletcher
bhfletcher over 5 years ago
The JTAG circuitry used on the Avnet MiniZed is a Xilinx solution based on the FTDI FT2232. As stated in https://www.xilinx.com/support/answers/68889.html, "the proprietary solution is not documented or supported, and cannot be provided to customers as a reference."
Please do NOT use the FT_PROG tool in conjunction with the MiniZed. The only way to fix it after erasing it is to send it back to the factory, which is more expensive than just buying a new MiniZed.
Bryan
