MiniZed Hardware Design How do I setup XILINX hardware target for Minized (Ubuntu 20.04 LTS)
  • Subscribers 358 subscribers
  • Views 2576 views
  • minized
sehaque
sehaque over 5 years ago
Hello, I have a Minized connected via direct USB cable to a physical Ubuntu host (not a Virtual Machine!) and I am having trouble in figuring out the required step to get it recognized as hardware target for XILINX Vivado toolchain.
My details:
  1. Linux Host: Small form server running  Ubuntu 20.04.2 LTS
  2. Vivado, Vitis, Vitis HLS version: 2020.2
All of the XILINX programs work. They need to see the hardware target to program, you know the hardware.
After insertion of of the USB cable, in the operating system we see:
[1135105.564912] usb 1-1.4: new high-speed USB device number 6 using ehci-pci
[1135105.677062] usb 1-1.4: New USB device found, idVendor=0403, idProduct=6010, bcdDevice= 7.00
[1135105.677063] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1135105.677064] usb 1-1.4: Product: JTAG+Serial
[1135105.677065] usb 1-1.4: Manufacturer: Xilinx
[1135105.677066] usb 1-1.4: SerialNumber: 1234-oj1
[1135105.678730] ftdi_sio 1-1.4:1.0: FTDI USB Serial Device converter detected
[1135105.678758] usb 1-1.4: Detected FT2232H
[1135105.679103] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUSB0
[1135105.680470] ftdi_sio 1-1.4:1.1: FTDI USB Serial Device converter detected
[1135105.680495] usb 1-1.4: Detected FT2232H
[1135105.680735] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUSB1
  1. Are there any prepatory TCL steps to take?
  2. Is there a installation script that I needed to run when installing the Avnet Minized tutorials?
  3. The tutorials are all for 2019.x versions, and are not current for 2020.2, but I can follow easily and have the Hello World application ready to go.
  4. Need to program it - but hardware target search comes up NIL.
Thanks!
  • sehaque
    Well, that was quick:
    I had previously run the install script, which is described here: https://www.element14.com/community/message/255019/l/minized-board-not-detected-by-vivadosdk#255019
    For me the install_drivers script was in /opt/xilinx/Vivado/2020.2/data/xicom/cable_drivers/lin64/install_script/install_drivers
    But I had not actually disconnected it and reconnected it so the process had not been done properly. All I had to do is disconnect/reconnect, and I am able to program the FPGA now with basic images.
    Regards
    N3RDX
  • sehaque
    sehaque over 5 years ago in reply to sehaque
    I can indeed program, but when running the hello world application, I get nothing  on the console (Vitis, Vivado).
    Is there a guideline on how to use the same USB port for programming, and also UART? Is the instruction in the tutorials #2 incorrect?
  • sehaque
    Ok, solved it after I found out that as a regular Ubuntu OS user I had to add that specific user into the 'dialout' group as suggested in an ASK UBUNTU post :
    https://askubuntu.com/questions/58119/changing-permissions-on-serial-port
  • drozwood90
    drozwood90 over 5 years ago in reply to sehaque
    Hi there,
    Sorry you ran into all of this.  A lot of people actually use our VM Install guide as a starting point to setup their hosts, be them virtual or not.  Next time, you (and others) can take a look there.  All of the issues you brought up (and luckily found answers!) are listed in the VM install guide.  Most of the document is setting up the OS/Tools, not the "VM".
    You can locate that document under out ZedSupport page:
    http://avnet.me/ZedSupport
    Choose the version of tools, then inside the VM_Install_Guide folder.
    I am glad you were able to locate your answer and you posted a response!  I am sure this will help others in the future!
    --Dan
