MiniZed Hardware Design MiniZed - Unable to get HelloWorld to Run
  • Subscribers 358 subscribers
  • Views 2476 views
  • minized
mvandepoel
mvandepoel over 5 years ago
I am attempting to run the Hello World application - first setting up the Zynq in Vivado 2020.2 and then running the standard Hello World C application through Vitis 2020.2. Following this tutorial: https://www.youtube.com/watch?v=Mb-cStd4Tqs&ab_channel=RobertSwan . The classic mistakes of putting the board into JTAG boot mode and changing the stdin/stdout to uart_1 have been solved.
When debugging/launching the code on my MiniZed over JTAG, I receive the following messages in the XSCT console. I cannot get it to print Hello World over UART, either in the Serial Terminal or through an external application like Tera Term.
Info: ARM Cortex-A9 MPCore #0 (target 2) Stopped at 0xffffff28 (Suspended)
_vector_table() at asm_vectors.S: 50
50: B _boot
Info: ARM Cortex-A9 MPCore #0 (target 2) Stopped at 0x10058c (Breakpoint)
main() at ../src/helloworld.c: 55
55:     init_platform();
When googling, similar error messaged appear but no clear instructions/understanding is given towards these errors.
I have attached my platform and application files below.
Any help/insight would be appreciated.
Kind Regards,
Mathijs
vitis_export_archive.ide.zip
  • bhfletcher
    bhfletcher over 5 years ago in reply to mvandepoel +1
    Are you able to run the default MiniZed design (located here Restore QSPI and eMMC Factory Images) and see things work? That is helpful to ensure your board, cables, and terminal setup are all working…
  • bhfletcher
    Did the board program correctly? Did the Blue DONE LED come on?
    Bryan
  • mvandepoel
    mvandepoel over 5 years ago in reply to bhfletcher
    Hi Bryan,
    Yes, the blue LED lights up.
    Mathijs
  • bhfletcher
    Are you able to run the default MiniZed design (located here Restore QSPI and eMMC Factory Images) and see things work? That is helpful to ensure your board, cables, and terminal setup are all working properly.
    Unfortunately, the messages that you share above simply look like you executed the program in the debugger and then didn't step through the code. If you could provide more detail as to what other errors you are seeing, we might be able to provide more help.
    Bryan
