MiniZed Hardware Design i2csensor app source code
  • Replies 9 replies
  • Subscribers 361 subscribers
  • Views 2352 views
100bikerglen
100bikerglen over 8 years ago
I'm looking for the source code for the i2csensor app that comes preinstalled in the flash on the minized board. I want to use the ST accelerometer in my own app and the i2csensor source code would be a great a starting point. Can someone point me to the source code? Thanks.
  • stefanrousseau
    0 stefanrousseau over 8 years ago
    Are you using Linux or do you need the code for a standalone project?  If you are using PetaLinux and have imported the BSP "minized.bsp" that is posted on the Reference Designs page, you can browse to
    <your project>project-spec/meta-user/recipes-apps/i2csensor/i2csensor/i2csensor.cpp
    It is part of the project that gets built by default.
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Bikerglen,
    You can find the standalone application source code here.
    https://avnet.egnyte.com/dl/F2GChNQeH4
    --Josh
  • 100bikerglen
    0 100bikerglen over 8 years ago
    Running standalone. The Avnet code on Egnyte is exactly what I need. Thanks!
    Last night I had the whoami register working then ported Adafruit's grains of sand demo to the board this morning: https://twitter.com/bikerglen/status/954425467796307968
  • rsiva
    0 rsiva over 7 years ago in reply to 100bikerglen
    Hello Josh
                          I am also interested in using the i2csensor as a base for both standalone and as a Linux app and need the source files (or vivado). I can get the minized.bsp from the reference/tutorial section but
    For the standalone, unfortunately the link given above is broken:
    // does not work
    Can you pl make it available.
    Siva R
  • jafoste4
    0 jafoste4 over 7 years ago in reply to rsiva
    i think this is what your looking for.
    https://avtinc.sharepoint.com/:u:/t/ET-Downloads/EYZ8xKO661dEng7239eOEqYBsDzLI21GT3jCm2R-YX0NGA
    -Josh
  • rsiva
    0 rsiva over 7 years ago in reply to jafoste4
    Hello Josh
                      Got it.  the new link works and I downloaded the file.
    Thanks much
    Siva R
  • stefanrousseau
    0 stefanrousseau over 7 years ago in reply to rsiva
    Hello Siva,
    If you are interested in both Standalone and Linux source for an I2C sensor, you can use this link:
    https://avtinc.sharepoint.com/:f:/t/ET-Downloads/EjfDz08HMXtLj2gHK9xID1oBwCRIYxh1pONFPETD1zhwYg
    We will soon (probably next week) publish a new design note on using SPI and I2C devices on MiniZed.  Under PetaLinux, this document will cover the use of the spidev and i2cdev drivers, with examples.
    Stefan
  • rsiva
    0 rsiva over 7 years ago in reply to stefanrousseau
    Hello Stefan
                         I downloaded the i2c files for the standalone and Linux from the link. The new tutorial will be fantastic that focusses on the SPI, I2C interfaces on the minized components and will be a starting point for doing more complex things. Pl let know when the reference is officially posted.
    Thanks much for your prompt support
    Regards
    Siva R
  • stefanrousseau
    An update on the tutorial/reference designs mentioned above: At MiniZed you can now download "Using SPI and I2C on MiniZed for Standalone and Linux".  This covers the use of conventional SPI and I2C interface usage in Standalone mode, as well as the use of the spidev and i2cdev drivers under Linux.  The MiniZed on-board devices (the ST motion&temperature sensor and the Dialog power supply) are used for I2C, while for SPI a VHDL SPI component in the PL is used to control an LED.
    Stefan
