MiniZed Hardware Design How to stream data directly from PL to eMMC?
  • Replies 8 replies
  • Subscribers 359 subscribers
  • Views 1349 views
hs15
hs15 over 8 years ago
I am trying to set up an experiment where I can stream data directly from PL to a txt file in eMMC then after a period of time send data to the backend computer through WiFi (TCP protocol). Similar procedure has been done in the "TDnext Pmod Camera" tutorial, however from PL to DDR and then WiFi to the backend computer (UDP protocol). As the DDR memory is volatile, I need to use eMMC instead. The original source code of the "TDnext Pmod Camera" application is not provided (the application comes with some .so .a files). Can anyone please assist me with this?
  • hs15
    0 hs15 over 8 years ago
    Can anyone at least provide the c app codes of the "TDnext Pmod Camera" tutorial? Now what I see are in .so, .a format...
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello hsole,
    I am working on getting this for you. I will have an answer for you tomorrow.
    Josh
  • hs15
    Many thanks!
  • jafoste4
    I am still waiting on hearing back from the developer. Will let you know when I have an updated.
    Josh
  • jafoste4
    Hello Hsoleimani,
    Unfortunatly the source code cannot be released publicly. Apologies.
    --Josh
  • hs15
    Can you please email it to me as I am your customer and currently using your Minized board?
  • hs15
    Can someone assist me with this please?
  • jafoste4
    Hello hsoleimani,
    Unfortunatly the source code you are requesting cannot be publicly released.
    Josh
