MiniZed Hardware Design non-root user cannot login using ssh
  • Subscribers 359 subscribers
  • Views 785 views
mhanuel
mhanuel over 8 years ago
I have been trying to make a non-root user accessible from ssh but it seems dropbear has a bug or something. I was trying to trace the cause so far without real clue.
A normal ssh login to root shows like this (debug enable)
ssh -v -v -v root@192.168.7.134
OpenSSH_6.7p1 Debian-5+deb8u4, OpenSSL 1.0.1t  3 May 2016
debug1: Reading configuration data /home/mhanuel/.ssh/config
debug1: /home/mhanuel/.ssh/config line 2: Applying options for *
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to 192.168.7.134 [192.168.7.134] port 22.
debug1: Connection established.
debug1: identity file /home/mhanuel/.ssh/id_rsa type 1
debug1: key_load_public: No such file or directory
debug1: identity file /home/mhanuel/.ssh/id_rsa-cert type -1
debug1: identity file /home/mhanuel/.ssh/id_dsa type -1
debug1: identity file /home/mhanuel/.ssh/id_dsa-cert type -1
debug1: identity file /home/mhanuel/.ssh/id_ecdsa type -1
debug1: identity file /home/mhanuel/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/mhanuel/.ssh/id_ed25519 type -1
debug1: identity file /home/mhanuel/.ssh/id_ed25519-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.7p1 Debian-5+deb8u4
debug1: Remote protocol version 2.0, remote software version dropbear_2016.74
debug1: no match: dropbear_2016.74
debug2: fd 3 setting O_NONBLOCK
debug3: load_hostkeys: loading entries for host "192.168.7.134" from file "/home/mhanuel/.ssh/known_hosts"
debug3: load_hostkeys: found key type RSA in file /home/mhanuel/.ssh/known_hosts:146
debug3: load_hostkeys: loaded 1 keys
debug3: order_hostkeyalgs: prefer hostkeyalgs: ssh-rsa-cert-v01@openssh.com,ssh-rsa-cert-v00@openssh.com,ssh-rsa
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ssh-rsa-cert-v01@openssh.com,ssh-rsa-cert-v00@openssh.com,ssh-rsa,ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ssh-ed25519-cert-v01@openssh.com,ssh-dss-cert-v01@openssh.com,ssh-dss-cert-v00@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519,ssh-dss
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,chacha20-poly1305@openssh.com,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se
debug2: kex_parse_kexinit: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-md5-etm@openssh.com,hmac-ripemd160-etm@openssh.com,hmac-sha1-96-etm@openssh.com,hmac-md5-96-etm@openssh.com,hmac-md5,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: curve25519-sha256@libssh.org,ecdh-sha2-nistp521,ecdh-sha2-nistp384,ecdh-sha2-nistp256,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1,kexguess2@matt.ucc.asn.au
debug2: kex_parse_kexinit: aes128-ctr,aes256-ctr,aes128-cbc,aes256-cbc,twofish256-cbc,twofish-cbc,twofish128-cbc,3des-ctr,3des-cbc
debug2: kex_parse_kexinit: hmac-sha1-96,hmac-sha1,hmac-sha2-256,hmac-sha2-512,hmac-md5
debug2: kex_parse_kexinit: zlib@openssh.com,none
debug2: mac_setup: setup hmac-sha2-256
debug1: kex: server->client aes128-ctr hmac-sha2-256 none
debug1: kex: client->server aes128-ctr hmac-sha2-256 none
debug1: sending SSH2_MSG_KEX_ECDH_INIT
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: RSA 15:aa:89:32:c8:44:d2:ac:9e:31:3f:f4:aa:47:50:9e
debug1: Host '192.168.7.134' is known and matches the RSA host key.
debug1: Found key in /home/mhanuel/.ssh/known_hosts:146
debug2: kex_derive_keys
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: /home/mhanuel/.ssh/id_rsa (0x55b1c1440ac0),
debug2: key: /home/mhanuel/.ssh/id_dsa ((nil)),
debug2: key: /home/mhanuel/.ssh/id_ecdsa ((nil)),
debug2: key: /home/mhanuel/.ssh/id_ed25519 ((nil)),
debug1: Authentications that can continue: publickey,password
debug3: start over, passed a different list publickey,password
debug3: preferred gssapi-keyex,gssapi-with-mic,publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Offering RSA public key: /home/mhanuel/.ssh/id_rsa
debug3: send_pubkey_test
debug2: we sent a publickey packet, wait for reply
debug1: Trying private key: /home/mhanuel/.ssh/id_dsa
debug3: no such identity: /home/mhanuel/.ssh/id_dsa: No such file or directory
debug1: Trying private key: /home/mhanuel/.ssh/id_ecdsa
debug3: no such identity: /home/mhanuel/.ssh/id_ecdsa: No such file or directory
debug1: Trying private key: /home/mhanuel/.ssh/id_ed25519
debug3: no such identity: /home/mhanuel/.ssh/id_ed25519: No such file or directory
debug2: we did not send a packet, disable method
debug3: authmethod_lookup password
debug3: remaining preferred: ,password
debug3: authmethod_is_enabled password
debug1: Next authentication method: password
root@192.168.7.134's password:
debug2: we sent a password packet, wait for reply
debug1: Authentication succeeded (password).
Authenticated to 192.168.7.134 ([192.168.7.134]:22).
debug1: Remote connections from LOCALHOST:52698 forwarded to local address 127.0.0.1:52698
debug1: channel 0: new [client-session]
debug3: ssh_session2_open: channel_new: 0
debug2: channel 0: send open
debug1: Entering interactive session.
debug1: remote forward success for: listen 52698, connect 127.0.0.1:52698
debug1: All remote forwarding requests processed
debug2: callback start
debug2: fd 3 setting TCP_NODELAY
debug3: packet_set_tos: set IP_TOS 0x10
debug2: client_session2_setup: id 0
debug2: channel 0: request pty-req confirm 1
debug1: Sending environment.
debug3: Ignored env XDG_VTNR
debug3: Ignored env SSH_AGENT_PID
debug3: Ignored env XDG_SESSION_ID
debug3: Ignored env VIRTUALENVWRAPPER_SCRIPT
debug3: Ignored env VIRTUALENVWRAPPER_PROJECT_FILENAME
debug3: Ignored env SDKMAN_SERVICE
debug3: Ignored env COMP_WORDBREAKS
debug3: Ignored env GPG_AGENT_INFO
debug3: Ignored env TERM
debug3: Ignored env SHELL
debug3: Ignored env XDG_MENU_PREFIX
debug3: Ignored env VTE_VERSION
debug3: Ignored env GRADLE_HOME
debug3: Ignored env GJS_DEBUG_OUTPUT
debug3: Ignored env WINDOWID
debug3: Ignored env GJS_DEBUG_TOPICS
debug3: Ignored env SDKMAN_PLATFORM
debug3: Ignored env NO_PROXY
debug3: Ignored env USER
debug3: Ignored env LS_COLORS
debug3: Ignored env SSH_AUTH_SOCK
debug3: Ignored env SDKMAN_BROADCAST_SERVICE
debug3: Ignored env SESSION_MANAGER
debug3: Ignored env USERNAME
debug3: Ignored env WORKON_HOME
debug3: Ignored env PROJECT_HOME
debug3: Ignored env PATH
debug3: Ignored env DESKTOP_SESSION
debug3: Ignored env VIRTUALENVWRAPPER_HOOK_DIR
debug3: Ignored env PWD
debug3: Ignored env JAVA_HOME
debug1: Sending env LANG = en_US.utf8
debug2: channel 0: request env confirm 0
debug3: Ignored env SDKMAN_VERSION
debug3: Ignored env GDM_LANG
debug3: Ignored env GDMSESSION
debug3: Ignored env SHLVL
debug3: Ignored env XDG_SEAT
debug3: Ignored env HOME
debug3: Ignored env no_proxy
debug3: Ignored env GNOME_DESKTOP_SESSION_ID
debug3: Ignored env XDG_SESSION_DESKTOP
debug3: Ignored env LOGNAME
debug3: Ignored env GROOVY_HOME
debug3: Ignored env SDKMAN_DIR
debug3: Ignored env XDG_DATA_DIRS
debug3: Ignored env DBUS_SESSION_BUS_ADDRESS
debug3: Ignored env SDKMAN_BROKER_SERVICE
debug3: Ignored env VIRTUALENVWRAPPER_WORKON_CD
debug3: Ignored env SDKMAN_CANDIDATES_DIR
debug3: Ignored env WINDOWPATH
debug3: Ignored env XDG_RUNTIME_DIR
debug3: Ignored env DISPLAY
debug3: Ignored env XDG_CURRENT_DESKTOP
debug3: Ignored env XAUTHORITY
debug3: Ignored env _
debug3: Ignored env OLDPWD
debug2: channel 0: request shell confirm 1
debug2: callback done
debug2: channel 0: open confirm rwindow 24576 rmax 32759
debug2: channel_input_status_confirm: type 99 id 0
debug2: PTY allocation request accepted on channel 0
debug2: shell request accepted on channel 0
Now I failing ssh to a user produces
  ssh -v -v -v mhanuel@192.168.7.134
  debug2: key: /home/mhanuel/.ssh/id_rsa (0x5631915acac0),
  mhanuel@192.168.7.134's password:
  Aiee, segfault! You should probably report this as a bug to the developer
  debug2: channel 0: rcvd eof
  debug2: channel 0: output open -> drain
  debug2: channel 0: obuf empty
  debug2: channel 0: close_write
  debug2: channel 0: output drain -> closed
  debug1: client_input_channel_req: channel 0 rtype exit-status reply 0
  debug2: channel 0: rcvd close
  debug2: channel 0: close_read
  debug2: channel 0: input open -> closed
  debug3: channel 0: will not send data after close
  debug2: channel 0: almost dead
  debug2: channel 0: gc: notify user
  debug2: channel 0: gc: user detached
  debug2: channel 0: send close
  debug2: channel 0: is dead
  debug2: channel 0: garbage collecting
  debug1: channel 0: free: client-session, nchannels 1
  debug3: channel 0: status: The following connections are open:
    #0 client-session (t4 r0 i3/0 o3/0 fd -1/-1 cc -1)
  Connection to 192.168.7.134 closed.
  Transferred: sent 3408, received 1640 bytes, in 0.0 seconds
  Bytes per second: sent 177666.9, received 85497.0
  debug1: Exit status 1
The root dir exists and has correct ownership.
I was thinking to isolate the issue and try to login using the serial console but cannot find how to disable auto-login, as it automatically login as root when boots, my inittab is
  root@MiniZed:~# cat /etc/inittab
  # /etc/inittab: init(8) configuration.
  # $Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
  # The default runlevel.
  # Boot-time system configuration/initialization script.
  # This is run first except when booting in emergency (-b) mode.
  si::sysinit:/etc/init.d/rcS
  # What to do in single-user mode.
  ~~:S:wait:/sbin/sulogin
  # /etc/init.d executes the S and K scripts upon change
  # of runlevel.
  # Runlevel 0 is halt.
  # Runlevel 1 is single-user.
  # Runlevels 2-5 are multi-user.
  # Runlevel 6 is reboot.
  l0:0:wait:/etc/init.d/rc 0
  l1:1:wait:/etc/init.d/rc 1
  l2:2:wait:/etc/init.d/rc 2
  l3:3:wait:/etc/init.d/rc 3
  l4:4:wait:/etc/init.d/rc 4
  l5:5:wait:/etc/init.d/rc 5
  l6:6:wait:/etc/init.d/rc 6
  # Normally not reached, but fallthrough in case of emergency.
  z6:6:respawn:/sbin/sulogin
  PS0:12345:respawn:/bin/start_getty 115200 ttyPS0
  # /sbin/getty invocations for the runlevels.
  # The "id" field MUST be the same as the last
  # characters of the device (after "tty").
  # Format:
  #  <id>:<runlevels>:<action>:<process>
  1:12345:respawn:/sbin/getty 38400 tty1
I inspect the start_getty but cannot find any reason for this.
Will appreciate your comments,
  • jafoste4
    0 jafoste4 over 8 years ago
    What development board are you working with?
    Josh
  • mhanuel
    0 mhanuel over 8 years ago in reply to jafoste4
    I am using petalinux 2017.4.
    Please let me know of anything to try.
  • mhanuel
    Hi @JFoster,
    I did a log when trying to login with an already created user
    First when a bad password is entered i can see
    May  1 00:21:37 MiniZed authpriv.info dropbear[1871]: Child connection from 192.168.7.109:36786
    May  1 00:21:44 MiniZed authpriv.warn dropbear[1871]: Bad password attempt for 'mhanuel' from 192.168.7.109:36786
    After the correct password I can see
      May  1 00:22:03 MiniZed authpriv.notice dropbear[1871]: Password auth succeeded for 'mhanuel' from 192.168.7.109:36786
      May  1 00:22:03 MiniZed authpriv.warn dropbear[1872]: lastlog_perform_login: Couldn't stat /var/log/lastlog: No such file or directory
      May  1 00:22:03 MiniZed authpriv.warn dropbear[1872]: lastlog_openseek: /var/log/lastlog is not a file or directory!
      May  1 00:22:03 MiniZed authpriv.info dropbear[1872]: Exit (mhanuel): Error changing directory
      May  1 00:22:03 MiniZed authpriv.info dropbear[1872]: Exit (mhanuel): login_init_entry: Cannot find user "mhanuel"
      May  1 00:22:03 MiniZed authpriv.info dropbear[1871]: Exit (mhanuel): Disconnect received
      Did you have the chance to test this issue?
