MiniZed Hardware Design FTDI FT2232H in Ubuntu
  • Subscribers 359 subscribers
  • Views 1833 views
I´m trying to use Minized in a Ubuntu 16.04.3 LTS system.
After connecting the USB cable, I can program the board through JTAG, but cannot access the UART port.
Looking at dmsg, the ttyUSB0 (uart?) port is getting disconnected soon after the cable is connected.
ttyUSB1 (jtag?) works fine.
I tried using two different boards, same behavior. In a Windows system the JTAG/UART dual USB-to-UART works fine.
Any ideas?
Follows dmsg results.
[ 4816.637755] usb 1-2: new high-speed USB device number 9 using xhci_hcd
[ 4816.785216] usb 1-2: New USB device found, idVendor=0403, idProduct=6010
[ 4816.785217] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4816.785219] usb 1-2: Product: JTAG+Serial
[ 4816.785219] usb 1-2: Manufacturer: Xilinx
[ 4816.785220] usb 1-2: SerialNumber: 1234-oj1
[ 4816.787167] ftdi_sio 1-2:1.0: FTDI USB Serial Device converter detected
[ 4816.787190] usb 1-2: Detected FT2232H
[ 4816.787307] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB0
[ 4816.788636] ftdi_sio 1-2:1.1: FTDI USB Serial Device converter detected
[ 4816.788660] usb 1-2: Detected FT2232H
[ 4816.788764] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB1
[ 4818.561830] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[ 4818.561859] ftdi_sio 1-2:1.0: device disconnected
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Joadullius,
    As you plug in your MiniZed two ports enumerate USB0 and USB1. For using the MinIZed you must connect to USB1. Try that and tell me how it worked.
    Josh
    0 e14 Contributor over 9 years ago
    Thanks for the Reply.
    I don't know why, but some days later both ttyUSB0 and ttyUSB1 started to work properly after cable pluging.
    May something was wrong with my Ubuntu system...
