MiniZed Hardware Design Using bluetooth in VHDL
  • Subscribers 358 subscribers
  • Views 596 views
t0rg31r
t0rg31r over 8 years ago
Hi!
I'm trying to implement the Bluetooth capabilities on my Minized to transfer either a log file or just some simple integers to my PC.
So far I've paired the board with my PC using Petalinux, but is there a way to do this in Vivado entirely and avoid using P-linux?
If this is not the case, suggestions or links for how to actually transfer the files in linux are welcome!
  • stefanrousseau
    0 stefanrousseau over 8 years ago
    I am unsure of what you mean by VHDL, since some of what is in the PL for the Bluetooth interconnect was done in VHDL.  If you look on http://zedboard.org/product/minized under Reference Designs, you will see a document inside "Using Bluetooth on MiniZed 2017.4".  This describes the interfaces and what is required on both the programmable logic and the processor system side.  You cannot use a standalone process running on the software side though.  It has to be Linux for the Type 1DX Bluetooth driver.
