MiniZed Hardware Design MiniZed wifi not connecting
  • Replies 9 replies
  • Subscribers 360 subscribers
  • Views 1627 views
chrisp_002
chrisp_002 over 8 years ago
Hi all,
Having trouble getting the MiniZed wifi to connect to anything. I've flashed the eMMC with stock image, and adjusted the wpa_supplicant at location..
/run/media/mmcblk1p1/wpa_supplicant
After doing this, I nativate to..
/usr/local/bin
Then I run the wifi.sh script at the above location. All I'm getting is 'Sending Discover', which repeats infinitely.
The ssid and psk entered into wpa_supplicant are both 100% correct, and the format of the document is the same as specified in the MiniZed getting started guide.
Any help would be appriciated!
Cheers,
Chris.
  • jafoste4
    0 jafoste4 over 8 years ago
    Hi Chris,
    please post your wpa_supplicant come text. Feel free to ***** our your ssid and password
    —josh
  • chrisp_002
    0 chrisp_002 over 8 years ago in reply to jafoste4
    Hi Josh,
    My wpa_supplicant currents reads as follows, the  " " marks are included in the actual document.
    ctrl_interface=/var/run/wpa_supplicant
    ctrl_interface_group=0
    update_config=1
    network={
             key_mgmt=WPA-PSK
             ssid="SomeAccessPoint"
             psk="password"
    Cheers,
    Chris.
  • stefanrousseau
    0 stefanrousseau over 8 years ago
    Hello Chris,
    Could you show some logs to help with diagnosing this?  After reset, to show what you are running, enter
    cat /proc/version
    Then please show the commands you enter and the results .
    Thank you,
    Stefan
  • jafoste4
    Hi Chris,
    What are you using as your Wifi? Can you try using your Phone as  hotspot to the device?
    --Josh
  • chrisp_002
    I've tried connecting to a standard 2.4GHz router, and a rapsberry pi set up as an access point. I can connect to both using other devices.
  • jafoste4
    Hi Chris,
    Were you able to do what was described by Stefan above?
    --Josh
  • chrisp_002
    I've managed to sort out this problem for now.
    I'm not longer using the wifi.sh script and bypassing wpa_supplicant. I'm now bringing up the wlan0 interface myself and using the command 'iw dev wlan0 connect' to make a connection to AP.
    Thanks for the replies,
    Chris.
  • stefanrousseau
    Hello Chris,
    It is great that your problem is resolved.  It woulkd be useful if you could please post the exact commands you are using instead of using the commands in wifi.sh.  Others who find this forum post and have the same issue that you were experiencing would value the detail.
    Thank you,
    Stefan
  • chrisp_002
    0 chrisp_002 over 8 years ago in reply to stefanrousseau
    stefanrousseau, Good call.
    This is the small script I used to connect to an access point over wifi.
    #Wifi startup script
    #Bring up wlan0
    ifconfig wlan0 up
    #First initialize wlan0 and connect to AP
    iw dev wlan0 connect -w ssidOfNetworkGoesHere!
    #Now start UDHCPC client side
    udhcpc -i wlan0
    Cheers,
    Chris.
