MiniZed Hardware Design PL clock Rate
  • Subscribers 358 subscribers
  • Views 940 views
PL clock Rate
tmichals
tmichals over 8 years ago
The minized board definition file configures the PL clocks to be:
FCLK_CLK0 - 50Mhz
FCLK_CLK1 - 100Mhz
FCLK_CLK2 - 50Mhz
FCLK_CLK3 - 50Mhz
Can FCLK_CLK0 be changed to 250Mhz?  Does all PL IP support this rate?
The reason for asking this, trying to do a Manchester serial decoder that supports 10Mhz, so, trying to find the start bit requires a 16x clock.  So, thought why not support the max ;)
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello tmichals,
    Those PL clocks support .1MHz - 250MHz clock speeds.
    I am sure some support that rate and some do not. Please look at the datasheet for whatever PL IP you wish to use to determine this.
    --Josh
