MiniZed Hardware Design building petalinux
  • Subscribers 359 subscribers
  • Views 879 views
building petalinux
jacobb
jacobb over 8 years ago
I am running into errors building peta-linux.  I will describe my steps bellow
so I source the make_minized_petalinux.tcl file to create a Vivado project.  Once the project is complete, I export the HDF file.
I then create an empty petalinux project and configure it with the HDF file from the Vivado project.
After configuring the project, I run petalinux-build.  After a few minutes, I get an error.
ERROR: Task (/home/jacob/Xilinx/petalinux_20174/components/yocto/source/arm/layers/meta-xilinx-tools/recipes-bsp/device-tree/device-tree-generation_git.bb:do_configure) failed with exit code '1'
The terminal mentions a log file and when I open up the log file, there is a critical warning that the board_part definiton was not found for em.avnet.com:minized:part0:1.2.
I presume this is what caused the error.
Any tips on what I am doing wrong in my work flow?
  • jacobb
    0 jacobb over 8 years ago
    Just to clarify, I am using version 2017.4 of Vivado and petalinux
  • jafoste4
    0 jafoste4 over 8 years ago
    Hey Jacob,
    Have you seen this UG? https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_1/ug1144-petalinux-tools-reference-guide.pdf
    --Josh
  • jacobb
    0 jacobb over 8 years ago in reply to jafoste4
    After a little more googling of my problem, I was able to figure out the problem.  The solution was actually documented in a Xilinx answer record.
    I guess I didn't see any mention of this in other documents, but for other people running into a problem building petalinux for the minized, I'll post the link to the solution below.
    https://www.xilinx.com/support/answers/70402.html
    https://forums.xilinx.com/t5/Embedded-Linux/Obscure-Patch-for-Minized/td-p/849250
