MiniZed Hardware Design Simulink on MATLAB 2017b error Vivado
  • Subscribers 359 subscribers
  • Views 750 views
100stefanoo
100stefanoo over 8 years ago
I'm trying to run the hdl_coder_blinking_4bit example to test my MiniZed to be programmed with Simulink under MATLAB 2017b (Windows10).
Everything goes fine until Generate RTL Code and IP core throw this error:
Task "Vivado IP Packager" unsuccessful
Error using hdlturnkey.ip.IPEmitterVivado/packageVivadoIP
Reinstalling Vivado didn't help. This problem persist with and without Xilinx license activated.
  • 100stefanoo
    100stefanoo over 8 years ago in reply to mbrown +1
    thanks mbrown running minized_setup.m every time before working on the board solved this problem (I'm using Vivado 2017.2)
  • mbrown
    0 mbrown over 8 years ago
    Which version of Vivado?
    This error is usually thrown when there's a path or access problem to the Vivado install folder.
    After installing the MiniZed Support Package for Simulink, did you run the minized_setup.m script (this is step #3 under "Set Up MATLAB")?
  • 100stefanoo
    0 100stefanoo over 8 years ago in reply to mbrown
    thanks mbrown
