MiniZed Hardware Design Problems with my Minized (cant boot linux)
  • Subscribers 359 subscribers
  • Views 520 views
t0rg31r
t0rg31r over 8 years ago
Hi!
I'm currently writing my bachelor thesis and my group has three minized's to work with.
Yesterday i was trying to flash the emmc to FAT and while it was loading i had to abort it so i just unplugged the cables. Now when i connect it and try to boot u-boot it just say "unable to read file image.ub".
I have tried reseting the entire board to factory settings using the official "Restoring MiniZed to Factory Status_03" from zedboard.org. This is supposed to reset the EMMC and QSPI with a new image.ub and boot.bin. I get the succes message but it still cant read the image.ub when i boot u-boot.
I have searched everywhere for this issue but cant seem to find anything.
Is there anything else I can do to reset this board somehow?
Also, while I'm at it, my SECOND Minized also have some issues. With this one, I can program the FPGA and run a simple hello world and get an output to terraterm, but if i try to reset it nothing happens. The LED's on the board change instantly when i press the reset button but nothing happens in terraterm. Note that the D8 LED is constantly at full luminosity, not flickering to the mic input (if it matters). I have also tried reseting it to factory settings with a success message but it still has the same issues..
  • jafoste4
    0 jafoste4 over 8 years ago
    First MiniZed
    How strange, please go through the tutorial once more and make sure you follow All steps. Let me know if the problem still exists
    Second MiniZed -
    Did you program the hello world over jtag? Jtag is volatile memory so when you reset it all is lost and needs to be reporgrammed.
    --Josh
  • t0rg31r
    0 t0rg31r over 8 years ago in reply to jafoste4
    I did try both flash and jtag, but the problem persisted.
    I did however try again today with the same settings and it actually worked! Dont know how or why though..
