MiniZed Hardware Design PetaLinux Board Support Packages
  • Replies 8 replies
  • Subscribers 360 subscribers
  • Views 1493 views
adamtaylorcengfiet
adamtaylorcengfiet over 9 years ago
Hi
When I try to download the PL board support package the site redirects me to my profile. Is there a broken link?
below is what I get when I click on it
http://zedboard.org/restrict/download/redirect?redirect=/sites/default/files/design/MiniZed_PL2016_4.zip
Also (it might be included with the above) but is it possible the share the Vivado project the petalinux build is based on such that I can add in some peripherals
Cheers
Adam
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Adam,
    I am not sure why you are encountering the issue you stated above. I was just successful in download the MiniZed BSP from here http://zedboard.org/support/design/18891/146 please give it one more try and let me know if you were successful. If not I have privately hosted the file here for you to download. https://avnet.egnyte.com/dl/7frNTnDDdT
    And yes the Vivado HW project is in the BSP as well.
    --Josh
    0 e14 Contributor over 9 years ago
    Hello, Adam!
    Actually bsp file is a zip archive.
    So you able to extract it and that you can see initial project.
    p.s. Tutorials are based on 2017.1 it would be nice to have bsp file for 2017.1 too (now it seems to be 2016.4).
    Best regards,
    ululuk21
    And I agree with Adam: Guide about how to create from scratch a full project which stored into qspi and emmc will be very helpful!
    Do you plan to update BSP to 2017.1 or 2017.2 ?
  • jafoste4
    We plan to produce a BSP for 2017.1 and then 2017.2 shortly after.
    --Josh
    Thanks!
  • olebon
    0 olebon over 8 years ago in reply to jafoste4
    Are there any plans to upgrade them to 2017.4?
    Is it practically possible to upgrade them myself?
  • jafoste4
    0 jafoste4 over 8 years ago in reply to olebon
    Hello olebon,
    We do plan to upgrad it to 2017.4 however this is a work in progress at this time.
    If you are interested in making your own 2017.4 BSP please refer to UG1156 version 2017.4
    https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug1156-petalinux-tools-workflow-tutorial.pdf
    --Josh
