MiniZed Hardware Design MiniZed and Matlab 2018.1 - File missing?
  • Subscribers 358 subscribers
  • Views 333 views
reykowski@bellsouth.net
reykowski@bellsouth.net over 8 years ago
Hi All,
I successfully installed the MiniZed hardware support package for SImulink and HDL coder.
When I open up the HDL Workflow Advisor I get the following warning message in the Matlab window:
Warning: File C:/ProgramData/MATLAB/SupportPackages/R2018a/toolbox/target/supportpackages/zynq/registry/attributes/xilinxZynqZC701AttributeInfo.xml not found
I checked, and the directory exists, but the file "xilinxZynqZC701AttributeInfo.xml" is not inside it.
Then, when I actually run the HDL Workflow Advisor in order to generate FPGA code, the advisor stops at "4.2 Generate Software Interface Model" with the error message:
Failed: The data for the selected hardware 'MiniZed' is invalid. Select a different hardware, or contact the vendor that provides the support for the target 'MiniZed'.
So I presume that the file "xilinxZynqZC701AttributeInfo.xml" is missing and that causes the HDL Workflow Advisor to fail. I de-installed and re-installed the MiniZed HW support package several times but that did not fix it. Any thoughts?
Regards, Arne
  • mbrown
    0 mbrown over 8 years ago
    Hi Arne,
    Our support package works with Vivado 2017.1 and 2017.2, MATLAB R2017a/b. MathWorks changed a few things in 2018a that are not compatible with our support package.
    /Matt
