MiniZed Hardware Design The MiniZed development board not supported by Vivado WebPack ?
  • Subscribers 359 subscribers
  • Views 1174 views
najmajose
najmajose over 8 years ago
I was trying to create a new zync project in Vivado. I am not able to find MiniZed in the list of boards supported by the Vivado tool ( downloaded fro here https://www.xilinx.com/support/download.html ).
 In the " Tutorial 01 Build a Zynq Hardware Platform" it says "The MiniZed development board is supported by Vivado WebPack (which is free) "
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello naj,
    It is supported.
    You have VIvado 2017.1 or later installed correct? That is when the 7007s zynq device on the Minized became supported in Vivado.
    Also did you install the MiniZed Board Definition file which can be located under the documentation section for the MIniZed?
    --Josh
  • najmajose
    0 najmajose over 8 years ago
    thanks Josh. MiniZed Board Definition file was missing. Installed it and problem solved
