MiniZed Hardware Design AXI TPG 7.0 device tree configuration boot problem
  • Subscribers 359 subscribers
  • Views 1416 views
mhanuel
mhanuel over 8 years ago
I am trying to use the AXI TPG 7.0 hooked to a AXI VDMA as shown here
<blockquote class="imgur-embed-pub" lang="en" data-id="a/Q04M5Nh"><a href="//imgur.com/Q04M5Nh"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
My hardware bitstream generate correctly. When updating petalinux project (2017.4) to use it, the plnx_arm-system.dts has the tpg entry like this
          v_tpg@43c20000 {
              compatible = "xlnx,v-tpg-7.0";
              reg = <0x43c20000 0x10000>;
              xlnx,s-axi-ctrl-addr-width = <0x8>;
              xlnx,s-axi-ctrl-data-width = <0x20>;
But that gave me some problem during booting, complaining about non existing node 0, I cannot find the exact error since I update the system-user.dtsi to become (before there wasno entry in system-user.dtsi)
  &v_tpg_0 {
      status = "okay";
      ports {
          #address-cells = <1>;
          #size-cells = <0>;
          port@0 {
              reg = <0>;
              xlnx,video-format = "yuv422";
              xlnx,video-width = <8>;
              tpg_out: endpoint {
                  remote-endpoint = <&axi_vdma_0>;
I try with and without the tpg_out endpoint with same error, which is
xilinx-tpg 43c20000.v_tpg: invalid format in DT
xilinx-tpg: probe of 43c20000.v_tpg failed with error -22
I understand the device tree should be something like explained here
https://github.com/Xilinx/linux-xlnx/blob/master/Documentation/devicetree/bindings/media/xilinx/xlnx%2Cv-tpg.txt
But the problem is that I am not using VTC driver (which I really I am unsure too if needed).
What I am trying to do is to feed the VDMA with a Test Image generated by TPG. I understand the new 7.0 IP is controlled in software (in my case kernel driver) by using kernel module xilinx-tpg.ko
http://www.wiki.xilinx.com/Xilinx+V4L2+TPG+driver
As far as I understand driver should load correctly so  /dev/v4l-subdev is listed.
I will appreciate anyone that can share some thoughts about what am I missing here.
Best,
  • mhanuel
    0 mhanuel over 8 years ago
    The bitstream image is at
    https://imgur.com/a/Q04M5Nh
  • kean0048
    0 kean0048 over 8 years ago
    the same with you,if you did it ,please where is the key point,thanks a lot
