MiniZed Hardware Design Programming the DA9062 PMIC
  • Subscribers 358 subscribers
  • Views 2378 views
  • power sequencing
  • power supply
  • otp
  • power management
  • one time programmable
  • pmic
avatarbecker
avatarbecker over 7 years ago
Hello there,
The MiniZed board uses the DA9062 PMIC for its power management.
My question is about how to configure it.
Since it uses I²C, I imagined one could first of all boot the PS (since PS and PL supplies are independent), program the PMIC via the I²C, and then perform power sequencing. But no, the only 3V3 net is generated by the DA9062 and, on top of that, it is the last voltage in the sequence.
I then assumed we are supposed to use the OTP, as mentioned in many parts of the datasheet. But how are we supposed to program it? I could not find any instructions related to it in the datasheet. Should we necessarily have the manufacturer program it before packaging?
I wonder if any of you guys has had any experience with that.
Any help is much appreciated, thanks in advance.
  • ctammann
    0 ctammann over 7 years ago
    Hey Wesley,
    We offer this device preprogrammed with the profile used on MiniZed as part number DA9062-10AM1. There are several app notes available on the Dialog device page, specifically check out the one on in circuit programming - https://www.dialog-semiconductor.com/products/power-management/pmics/DA9062
    Bottom line, outside of using the eval board to create your design, most often you will populate the device on your board preprogrammed with the configuration you have designed. Take a look at some of these app notes and if you still have questions please don't hesitate to reach back out to me.
    Chris
  • DA9062
    0 DA9062 over 3 years ago in reply to ctammann
    Does anybody offer this device preprogrammed for Xilinx Artix-7 FPGA? Who do I contact to get this done? Thanks.
