MiniZed Hardware Design Minized can not terminate Wifi startup script
  • Subscribers 359 subscribers
  • Views 798 views
anttiw
anttiw over 7 years ago
I did followed the tutorial from Simulink where Minized is connected to wlan. Unfortunately it didn't worked for me.
https://se.mathworks.com/matlabcentral/fileexchange/66004-avnet-minized-support-package-for-simulink
Now the board starts and continues endless loop "
Starting MiniZed WiFi services
ifdown: interface eth0 not configured
Successfully initialized wpa_supplicant
rfkill: Cannot open RFKILL control device
IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
udhcpc (v1.24.1) started
Sending discover...
Sending discover...
Sending discover...
Sending discover...   "
Any idea how to terminate this script? I tried Ctrl+C and some other combinations in terminal window. How would you terminate or skip this script? Problem is that the command line newer appears or login prompt. This is just endless loop. Earlier discussion was found earlier forum, but it's not described how to stop or terminate this wlan beahaviour.
The problem might be solved like in this forum MiniZed wifi not connecting | Zedboard
But how to terminate this endless loop?
BR Antti
  • anttiw
    anttiw over 7 years ago +1 verified
    Yep, crtl + break did this job finally! -antti
  • anttiw
    0 anttiw over 7 years ago
    -antti
  • clem57
    0 clem57 over 7 years ago in reply to anttiw
    Good command to know under Linux.
