MiniZed Hardware Design suitable ethernet phy chip for ps side of XC7Z020/XC7Z010
  • Subscribers 359 subscribers
  • Views 1956 views
hasila
hasila over 4 years ago
Hi all,
I am trying to make my own low cost XC7Z020/XC7Z010 based board. I am referring the microzed schematic and picozed schematic... the thing is with the phy chip attached to the ps. the both boards are using 88E1512-A0-NNP2I000 which is very expensive(~35 usd). I have attached the schematic with this post. so I want to change this phy chip and go for a cheaper option. but my concern is....are there any reason why this has been selected even for this kind of development board... is it okay to go for a cheaper option like RTL8211E-VL which is used in the zybo board... I would be most grateful if someone can give me a clear idea about this or what are the criteria need to be consider apart from voltage levels of the zynq chip and RMII compatibility.
kind regards
  • cstanton
    0 cstanton over 4 years ago
    Feedback and Support is for Community support issues, I've moved this thread to Avnet & Tria Boards Community, please make sure you've joined the group.
    0 Jan Cumps over 4 years ago
    The Pynq-Z2 board also uses Realtek RTL8211. It is half the price, but hard to get. Octopart lists 40 parts available.
  • jafoste4
    0 jafoste4 over 4 years ago
    Hi Hasila,
    As of recent here at Avnet we have been reccomending the KSZ9131RNX PHY from Microchip. We have seen quite a bit of success with it.
    One issue you will face is availablity, however that is across the market.
    -Josh
  • bhfletcher
    0 bhfletcher over 4 years ago in reply to jafoste4
    The KSZ9031 is an earlier generation of the KSZ9131 that you will find on Avnet's Network FMC card. If you are having trouble finding PHYs, you could prototype with an FMC card while you are on the waiting list to get the phys.
    https://www.avnet.com/shop/us/products/avnet-engineering-services/aes-fmc-netw1-g-3074457345635205181/
    Bryan
