MiniZed Hardware Design Can MInized drive stepper Motor driver ULN2003A?
  • Subscribers 356 subscribers
  • Views 1473 views
koseiyokoyama
koseiyokoyama over 2 years ago
Can Minized drive Stepper motor driver (one in ELGOO kit) ?
Motor driver uses TI ULN2003A IC to dirve stepper motor (28BY-J-48)
I wrote RTL to drive stepper motor driver from Minized GPIO,
but it does not seems GPIO drive stepper motor driver
thank for your help
  • javagoza
    javagoza over 2 years ago +1
    The first thing you need to check is if the signal on the GPIOs you are using is correct. At the logic level, you can use the ILA (Integrated Logic Analyzer) on the FPGA and observe from Vivado. If the…
  • javagoza
    0 javagoza over 2 years ago
    The first thing you need to check is if the signal on the GPIOs you are using is correct. At the logic level, you can use the ILA (Integrated Logic Analyzer) on the FPGA and observe from Vivado. If the logic is correct, then check without connecting the ULN2003A if the voltage levels that the Minized gives you are sufficient for TTL, greater than 2V1.
  • koseiyokoyama
    0 koseiyokoyama over 2 years ago
    Thanks for your replys. I will be back to this project in couple of weeks
  • koseiyokoyama
    0 koseiyokoyama over 2 years ago in reply to javagoza
    Thanks, Javagoza,
    I have done your suggestion and finally stepmotor is stepping!
    again, thanks for your help!!
  • javagoza
    0 javagoza over 2 years ago in reply to koseiyokoyama
    I'm glad you solved it. Watching a stepper motor work with your own development is very rewarding.
