MiniZed Hardware Design About Programming and Obtaining Configuration Files for IRPS5401MTRPBF
  • Subscribers 357 subscribers
  • Views 339 views
sdimen
sdimen over 1 year ago
Hi everyone,
I am designing a custom carrier board and plan to use Infineon's IRPS5401MTRPBF PMIC with the UltraZed-EG SOM. I understand that the device needs to be programmed to meet specific power requirements.
Programming Method: Programming of the IRPS5401MTRPBF requires the use of the PowIRCenter tool provided by Infineon. The tool allows the user to configure the PMIC's output voltage, startup sequence, and other parameters according to specific application requirements.
Configuration File Obtaining: If you want to use the same configuration as the UltraZed-EG SOM carrier board, you can contact the relevant designer or community member to obtain the PowIRCenter configuration file for the design. In previous discussions, the designer has indicated that such a configuration file is available.
Pre-programmed device procurement: Typically, the IRPS5401MTRPBF is supplied in an unprogrammed state. If you need a pre-programmed device, you may need to contact a vendor or use a programming service. For example, Avnet offers a device programming service that can be customized to your needs.
