Monarch Go File Upload/Download examples
  • Subscribers 352 subscribers
  • Views 912 views
jeffadi
jeffadi over 2 years ago
Does anyone have any examples of ftp upload or download using AT Commands that actually work?
Or even HTTP file download?
The examples in the "SR1.2.0.0 Use Cases with AT Commands" don't work.
When I try to duplicate the example in 4.3.2 Use Cases with +SQNHTTP Commands I get the following
AT+SQNHTTPCFG=2,"httpbin.org",80
\r\n
OK\r\n
AT+SQNHTTPQRY=2,0,"/"
\r\n
OK\r\n
\r\n
+SQNHTTPRING: 2,200,"text/html; charset=utf-8",9593\r\n
AT+SQNHTTPRCV=2,0"
\r\n
ERROR\r\n
Really need help here. TIA
    shabaz over 2 years ago +1
    You've not provided a link to the documentation you're using, so I can't compare, but it looks like you've got a quotation mark appended on a line where there shouldn't be one. If you remove that.hopefully…
    You've not provided a link to the documentation you're using, so I can't compare, but it looks like you've got a quotation mark appended on a line where there shouldn't be one. If you remove that.hopefully it will work.
  • jeffadi
    jeffadi over 2 years ago in reply to shabaz
    Thank you Shabaz. That was the issue.
    I must have stared at that for hours. Sometime you can't see the forest for the trees.
