PicoZed Hardware Design 7015/7030 Rev C 3D Model
  • Subscribers 357 subscribers
  • Views 1015 views
I am currently designing a carrier board for the 7030 PicoZed. Could I please get access to the Rev C 3D model of the board. I was using the Rev B model that is currently on the website, but me looking at a Rev C board in my hand, the new C100, C135, C137, C194 capacitors significantly change the height profile on the underside of the board. Thank you.
  • bhfletcher
    Yes, I have requested it from engineering.
    Bryan
    The Rev C update to the PicoZed 7015/7030 STEP model has been posted.
    -Gary
    Thanks for the quick turn-around guys. I appreciate it.
    I should note though that the capacitors that I mentioned appear to be (just guessing) ~1.3mm tall in the step file, while in the hardware I have they are ~2.54mm tall. The model still gives me the placement, so that should be good enough for me to go off of, but just wanted to warn others.
  • bhfletcher
    Thanks for your feedback. We pointed this out to engineering, and they acknowledged that there is a mistake in the database model for the height of this 1210 Cap component:
    The height of the 3D Step files for the 1210 Caps in the Rev A, B, and C BOMs are 1.016mm tall, and they should be 2.5mm for the part number that is being populated.
    They are going to work on replacing that part with a corrected one and then re-generate the 3D model for the board.
    Bryan
