PicoZed Hardware Design PicoZed Carrier Card V1 - PS USER LED D1 red
  • Subscribers 358 subscribers
  • Views 950 views
vda
vda over 9 years ago
I am working with a Picozed 7020 (carrier card v1), i take my program in a SD card and i put this one on the board for run my program. But now i have a problem when i run my program on the board, the D1 PS USER LED is in red ,the "FPGA DONE is off" and no program is  running
Do you have solution for this problem ?
PS: The Board run with Linux but not with SDCARD
  • vda
    0 vda over 9 years ago
    states of leds:
    D1 RED
    D21 OFF
    D19 GREEN
    D14 GREEN
    thank you
  • zedhed
    0 zedhed over 9 years ago
    Hi VDA,
    Sorry to hear you are having trouble with your PicoZed 7020 system.
    If you have followed the instructions on the Quick Start Card and are still having problems booting Linux, please download the "Restore/Upgrade QSPI Factory Image" from the PicoZed FMC Carrier Card V1 Reference Design/Tutorials page here:
    http://picozed.org/support/design/4701/76
    That design should get you booting Linux from the SD card in order to restore the QSPI and eMMC programming.
    -Kevin
  • vda
    hi zedhed,
    My board run with Linux OS but when i want to use SDcard for running my program (Helloworld) I have this problem.
    Thank you
  • vda
    I use a standard PicoZed 7020 with Carrirer card V1
  • zedhed
    Hi VDA,
    Can you describe the steps that you are using (including tool versions) to implement Hello World under Linux?
    Having a better understanding of what steps you are following will help us offer better advice for troubleshooting this issue.
    -Kevin
  • vda
    I have the solution for my problem;
    The D1 PS USER LED was in red because when i download the program on my SD card i forgot to put the FSBL file on SDK.
    Dass
