PicoZed Hardware Design SWDT problem
  • Subscribers 357 subscribers
  • Views 604 views
SWDT problem
I want to enable SWDT option on my zynq 7010 design through EMIO and then make it external (assign to bank 34).
but after I finished generate bitstream and import to SDK, FPGA programming was failed.
This problem happen only when SWDT option enabled.
If I disabled SWDT, FPGA programming is succesfull.
Please give me an advice..
Thank you
    Hello Ivan,
    Did you make sure to select an active clock for the SWDT?
    Also, what version of Xilinx tools are you using? Your host PC OS?
    -Gary
    hello gary,
    I am using vivado 2014.4 with windows 8 os.
    Yes I select 1x CPU active clock for swdt.
