PicoZed Hardware Design Connecting Picozed with LCD Panel
  • Subscribers 358 subscribers
  • Views 463 views
Hi
I need to connect picozed bank 34 to LCD panel through LVDS interface. What IP I should add on PL side?
  • zedhed
    0 zedhed over 10 years ago
    Hi Ivan,
    I suggest taking a look at what we do for our Zed Display Kit reference designs on the other Zed platforms.
    http://microzed.org/support/design/1668/13
    Although we cannot provide support for connecting other display panels, that design should give you a head start or at least an idea of what type of IP you would need to add to your PL design.to
    Keep in mind for the PZ7030 module that Bank 34 I/O voltage must be set to 1.8V which removes the ability to use LVDS_25 I/O standard on that bank in your LCD panel designs.
    -Kevin
    0 e14 Contributor over 10 years ago in reply to zedhed
    Hi Kevin,
    Thank you very much for your advice.
    It really help.
