PicoZed Hardware Design NOT SMA
  • Replies 7 replies
  • Subscribers 359 subscribers
  • Views 1111 views
NOT SMA
I have the Picozed carrier card V1 and in the documentation and schematics there are SMA connectors on the board.
But not on the actual board, what is it?!
And Why?
This made me a bit disappointed...
    Hello Johan,
    I am not sure what board you have, but the PicoZed FMC Carrier Card V1 does have 6 SMA connectors. The picture of the board on the product page is of an older version that had 8 SMA connectors, but the current Users Guide shows the current configuration:
    http://zedboard.org/sites/default/files/documentations/PZCC-FMC_UG_1.1.pdf
    -Gary
    As far as I know this is not SMA connectors:
  • jafoste4
    0 jafoste4 over 10 years ago
    Hello Johan,
    Are you sure you have the PicoZed FMC Carrier Card V1? If you refer to the documentation that Gary provided above it states that the PicoZed FMC Carrier Card V1 does have 6 SMA Connectors. Please refer to page 3 of that document where it talks about interfaces.
    - Josh
  • jcy
    0 jcy over 9 years ago in reply to e14 Contributor
    Hi, Johan, have you solved this problem? I also don't know the explicit type of the connector which is wrongly described as SMA in user guide. If you have solved this problem, please tell me the type of this connector, thank you.
  • jafoste4
    0 jafoste4 over 9 years ago in reply to jcy
    Hello JCY,
    I am going to link your other post to help others incase they have a similar issue.
    http://zedboard.org/content/asking-right-type-transceiver-connectors-picozed-fmc-carrier-card-v1
    --Josh
  • drozwood90
    0 drozwood90 over 9 years ago
    johan.huldberg,
    Please private message me with your serial number.
    --Dan
