PicoZed Hardware Design XAPP1171 for PicoZed
  • Subscribers 359 subscribers
  • Views 2076 views
100houssam
100houssam over 8 years ago
Hi all,
I have a PicoZed 7Z030 and I would like to enquire if someone has already implemented the xapp1171 project  (PCI Express Endpoint-DMA Initiator Subsystem) for the PicoZed.
If so, it would be greatly helpful to help me find it.
If not, maybe point me in the direction of another project for the PicoZed 7Z030 that uses endpoint PCIe based design to send Data.
Regards!
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Houssam,
    Have you tried taking a look at the PCIe End Point Reference Design that we offer? It can be found here
    http://zedboard.org/support/design/13076/106
    --Josh
  • 100houssam
    0 100houssam over 8 years ago in reply to jafoste4
    The main issue with that design, is it uses the "7 Series FPGAs Integrated Block for PCI Express" IP block instead of the "AXI memory mapped to PCI Express" IP block, which turned out more complicated and less convenient for me
    I only want to send data from DDR to an outside Root Port PCIe device using the Picozed PCIe X1
  • drozwood90
    0 drozwood90 over 8 years ago
    Hi there,
    At this time we do not have an AXI to PCIe design.  The above listed example is the only one at this time.
    I think if you follow the XAPP you listed above you will do well!
    --Dan
  • heldur86
    0 heldur86 over 4 years ago
    Hi Houssam EL LAKKIS!
    Is it possible to contact you directly? Via PM, via another channel?
    I would like to talk about AES-Z7PZ-7Z030, that you have been using.
    Thank you!
    Heldur
