PicoZed Hardware Design Camera output bit width for PicoZed Embbeded & Smart Vision Kit
  • Subscribers 357 subscribers
  • Views 437 views
Can anyone tell me the no. of R, G and B bits the camera Aptina 0134 (which comes with PicoZed smart vision kit) and ON PYTHON-1300-C camera module (which comes with PicoZed embedded vision kit) outputs per pixel?
It's not quite clear in the datasheet of PYTHON-1300-C were it's mentioned 10 bit output per pixel, does it mean total R+B+G  = 10 bits or 10 bits for each color? Similar is the case for Aptina 0134 sesnor.
BJ
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello BJ,
    the AR0134 image sensor's pixels are monochrome. Meaning it is only made up of one color.
    For the PYTHON-1300-C image snsor, pixels are in bayer format. This means that each pixel only has one of the three primary colors(RGB). A CFA (color filer array interpolation) is required to generate the missing color components.
    http://www.siliconimaging.com/RGB%20Bayer.htm
    The Avnet reference design preserves 8 bits after the conversion, for a total of 24 bits.
    http://zedboard.org/support/design/14961/111
    --Josh
