PicoZed Hardware Design PicoZed PLL-based clocks
  • Subscribers 358 subscribers
  • Views 422 views
marcomercuri85
marcomercuri85 over 9 years ago
Hi all,
I'm new with the PicoZed.
I would like to send the PL system clock FCLK_CLK0 to one pin of the PL MOD ports (JZ1, JA1, JB1). An alternative also to the PS MOD port. Is it that possible?
How should be the constraints file?
Thank you very much in advance.
Best Regards,
Marco
  • jafoste4
    0 jafoste4 over 9 years ago
    Hi Marco,
    It should be possible to get your FCLK_CLK0 out through a PL PMOD port on the PicoZed Carrier Card. It will not be possible through the PS PMOD Port. For constraint help take a look at the master constraint file located here(assuming you are using the PicoZed FMC V2)
    http://zedboard.org/support/documentation/13076
    --Josh
  • marcomercuri85
    0 marcomercuri85 over 9 years ago in reply to jafoste4
    Hi Josh,
    I succeeded getting CLK0.
    Thanks a lot.
    Best Regards,
    Marco
