PicoZed Hardware Design 10G Ethernet on the Picozed
  • Subscribers 357 subscribers
  • Views 749 views
kkarras
kkarras over 9 years ago
Hi all,
    Does anybody know if the Picozed (with carrier kit) support 10G Ethernet connection through the SFP+ interface? Assuming of course one has access to all the appropriate Xilinx IP.
Cheers
  • drozwood90
    0 drozwood90 over 9 years ago
    Hi there,
    While the cage and routing is designed for higher speeds, I would not suggest this as the fastest PicoZed has 6.6Gbps GTX transceivers.  If you want a true 10Gbs setup, please take a look at our Mini-Module Plus.  It can be purchased in a configuration that exceeds the 10Gbps Ethernet speeds.
    --Dan
  • kkarras
    0 kkarras over 9 years ago
    Thanks Dan, that makes complete sense. We'll just start out with a 1Gbps design for now and move on later.
    --Kimon
  • drozwood90
    Hi there,
    You are most welcome.
    If you take a look at the AZTEK Product brief, you can see on the second page a list of standard protocols and their speeds.
    http://zedboard.org/product/picozed-aztek-transceiver-evaluation-kit
    --Dan
