PicoZed Hardware Design Download bitstream from SDK to PicoZed FMC Carrier Card V2
  • Subscribers 357 subscribers
  • Views 414 views
paolofalconearesys
paolofalconearesys over 9 years ago
Hi there,
Today we received the PicoZed FMC Carrier Card V2 and we want to work with it.
We already have a simple project created in Vivado for such a target and we want to download the bitstream to the Picozed.
We looked at the reference design tutorial (http://zedboard.org/sites/default/files/design/02_MZPZ_Zynq_Hello_World_2016_4_01.zip) to understand how to set the board to dowonload bitstream from Xilinx SDK, but it seems that explanations are provided for FMC Carrier Card V1.
How can we proceed to setup the FMC Carrier Card V2 to download bitstream from SDK?
Thank you in advance for your help.
  • jafoste4
    0 jafoste4 over 9 years ago
    Hi paolofalconearesys,
    Thanks for pointing that out. I will update it with the correct hardware setup instructions for the PicoZed FMC V2 in the next release. If you refer to Tutorial 05 Echo Server Vivado 2016.4 located at :
    http://zedboard.org/support/design/13076/106
    on page 10 of that document it goes over the instruction in setting up your PicoZed FMC V2 hardware. Just follow that setup and you will be good to go.
    Josh
