PicoZed Hardware Design PicoZed 7030 TPS54618 regulator
  • Subscribers 357 subscribers
  • Views 513 views
For the PicoZed 7030 module, the EN pin of U11 (TPS54618 switch mode regulator) is pulled high via R52 to VIN (schematic sheet 11).
The TPS54618 has an absolute maximum rating spec on its EN pin of 4 V.  (See TPS54618 data sheet, section 6.1)  So, if the carrier sets VIN = 5V, then this rating will be exceeded.
Please advise.
Thank you,
Roopa
  • bhfletcher
    0 bhfletcher over 10 years ago
    Roopa,
    This is an issue. Please see the post below, as well as PCN16004 and PicoZed 7015/7030 Rev C Errata 1.2 posted on the Documentation page for PicoZed.
    http://zedboard.org/content/picozed-7015-7030-users-action-needed
    Bryan
    0 e14 Contributor over 10 years ago in reply to bhfletcher
    Thank you!
