PicoZed Hardware Design Picozed Embedded Vision Kit, Vivado 2017.2
  • Subscribers 357 subscribers
  • Views 463 views
100darin
100darin over 8 years ago
Hi, searched for this, but couldn't find anything. Just learning, so please excuse the basic nature of the questions.
I'm trying to build the design contained in FMC-HDMI-CAM + PYTHON-1300-C Reference Design Tutorial (2015.4 - webpack).
I'm following the instructions, (discovered I had to install the board support files, not called out in the instructions, or I missed it).
I'm at the point where I've fetched the design from github, I can run the make_fmchc_python1300c.tcl script, and I get:
WARNING: [IP_Flow 19-2162] IP 'fmchc_python1300c_v_cfa_0_0' is locked:
* IP 'fmchc_python1300c_v_cfa_0_0' requires one or more mandatory licenses but no valid licenses were found. However license checkpoints may prevent use of this IP in some tool flows.
Please select 'Report IP Status' from the 'Tools/Report' menu or run Tcl command 'report_ip_status' for more information.
| Video IP Core    | License Status                     |
| v_cfa            | INVALID                            |
| v_cresample      | INVALID                            |
| v_osd            | INVALID                            |
| v_rgb2ycrcb      | VALID (Full License)               |
| v_tc             | VALID (Full License)               |
ok, so I run the license TCL script and get:
| Instance Name                            | Status               | Recommendation      | Change    | IP Name            | IP      | New Version   | New        | Original Part        |
|                                          |                      |                     | Log       |                    | Version |               | License    |                      |
| fmchc_python1300c_processing_system7_0_0 | Up-to-date           | No changes required |  *(1)     | ZYNQ7 Processing   | 5.5     | 5.5 (Rev. 5)  | Included   | xc7z030sbg485-1      |
|                                          |                      |                     |           | System             | (Rev.   |               |            |                      |
|                                          |                      |                     |           |                    | 5)      |               |            |                      |
| fmchc_python1300c_v_cfa_0_0              | IP license not found | Check IP license    |  *(2)     | Color Filter Array | 7.0     | 7.0 (Rev. 11) | Needs      | xc7z030sbg485-1      |
|                                          |                      |                     |           | Interpolation      | (Rev.   |               | Purchase   |                      |
|                                          |                      |                     |           |                    | 11)     |               |            |                      |
| fmchc_python1300c_v_cresample_0_0        | Up-to-date           | No changes required |  *(3)     | Chroma Resampler   | 4.0     | 4.0 (Rev. 11) | Design_Lin | xc7z030sbg485-1      |
|                                          |                      |                     |           |                    | (Rev.   |               |            |                      |
| fmchc_python1300c_v_osd_0_0              | Up-to-date           | No changes required |  *(4)     | Video On Screen    | 6.0     | 6.0 (Rev. 13) | Design_Lin | xc7z030sbg485-1      |
|                                          |                      |                     |           | Display            | (Rev.   |               |            |                      |
|                                          |                      |                     |           |                    | 13)     |               |            |                      |
| fmchc_python1300c_v_rgb2ycrcb_0_0        | Up-to-date           | No changes required |  *(5)     | RGB to YCrCb       | 7.1     | 7.1 (Rev. 10) | Included   | xc7z030sbg485-1      |
|                                          |                      |                     |           | Color-Space        | (Rev.   |               |            |                      |
|                                          |                      |                     |           | Converter          | 10)     |               |            |                      |
| fmchc_python1300c_v_tc_0_0               | Up-to-date           | No changes required |  *(6)     | Video Timing       | 6.1     | 6.1 (Rev. 10) | Included   | xc7z030sbg485-1      |
|                                          |                      |                     |           | Controller         | (Rev.   |               |            |                      |
|                                          |                      |                     |           |                    | 10)     |               |            |                      |
It builds a bunch of *.xdr files, but no *.bin file as the tutorial suggests.
Any hints?
  • 100darin
    0 100darin over 8 years ago
    OK, that was stupid simple.
    Went to the Xilinx license manager site and grabbed some hardware eval licenses for the IP in question.
