PicoZed Hardware Design MGT Power sequencing
  • Subscribers 357 subscribers
  • Views 322 views
Are there any power sequencing requirements for MGTAVTT and MGTAVCC?  I was planning on creating these with LDO's that are based off a 1.8V PS that is used for VCCIO banks.  The 1.8V PS would be enabled by VCCIO_EN.  Is this acceptable or do the MGT PS's need  to turn on earlier or later?
  • ctammann
    0 ctammann over 12 years ago
    The MGTAVCC needs to come up before the MGTAVTT (1V before 1.2V).  The requirement is that both the 1V core and the 1V MGT rail come up before the 1.2V MGT rail.  If you use the VCCIO_EN signal to enable your transceiver 1V supply, then use the 1V supply to enable the 1.2V supply you will be fine.
    Chris
