PicoZed Hardware Design bare metal eMMC usage?
  • Subscribers 357 subscribers
  • Views 862 views
Has anyone used the eMMC on the picozed from a bare metal application?
I know that I need to use sdps to bring up the eMMC card before I can use xilffs, but I can't initialize the card. I obviously added xilffs to my bsp and enabled mmc support.
I have no real clue what the procedure is for bringing up the interface and there isn't any real sdps documentation anywhere that I can find.
Any pointers? Help?
    Once you have formatted the eMMC device you should be able to access it with the same drivers/code you use for a 'standard' SD Card.
    There is an application note on the PicoZed FMC Carrier Card Reference Designs/Tutorials page: http://zedboard.org/support/design/4701/76
    that has instructions on formatting the eMMC using Linux. http://zedboard.org/sites/default/files/design/PicoZed_Petalinux_2014_4_eMMC_boot_v2_1.zip
    Once formatted you can use U-Boot or other drivers to access the files system on the device.
    -Gary
    Gary's message seems to indicate in order to access the eMMC chip we need to format it to FAT? Is there a way to access the sectors in the eMMC chip?
