PicoZed Hardware Design Question about PicoZed FCI connectors
  • Subscribers 357 subscribers
  • Views 534 views
oscargomezf
oscargomezf over 10 years ago
Hi everyone,
I'm reading the  document PZCC-FMC-V2-UG_1.0.pdf, and I think there is an error in the 2.9 section, on the page 19/42:
"2.9 JX1, JX2 and JX3 SOM Interface MicroHeaders
The PicoZed Carrier has three 100-pin MicroHeaders (FCI, 61082-101400LF) for connection to the SOM. The stack height is 5mm for each of these connectors."
The 61082 series is a receptacle. I think it has to be 61083 Plug.
In the document PicoZed 7015_7030_User's_Guide_v1.6.pdf, in the section 2.8.1, on the page 15/32:
"2.8.1 Micro Headers
PicoZed 7015/7030 features three 100-pin Micro Headers (FCI, 61082-103400LF) for connection to carrier cards."
So in the picoZed, the connectors are 61082-103400LF (receptacle), and in the picoZed FMC carrier V2 has to be  61083-101400LF (plug).
Could you confirm I'm right?
Best regards.
  • jafoste4
    0 jafoste4 over 10 years ago
    Hello Oscargomezf,
    I just looked into this and you are correct. Thank you for alerting us to this mistake. I have updated the document to reflect the build.
    Thanks again!
    --Josh
