PicoZed Hardware Design PicoZed board definition files for Vivado 2018
  • Subscribers 358 subscribers
  • Views 1328 views
  • vivado
  • board definition files
mathj
mathj over 7 years ago
Hello
I have found PicoZed board definition files for older versions of Vivado and definition files for fmc carriers, but have been unable to make either work.
I am working with a custom board with a PicoZed 7020 and I need the board definition files.
Should the definition files for the older versions and for the carrier boards work regardless, even though I have been unsuccesful?
I think Vivado comes with board definition files related to the Zed, is this relevant?
Thanks in advance.
  • jafoste4
    0 jafoste4 over 7 years ago
    Hi Mathias
    Please follow this guide for installing the latest BDF for PicoZed.
    http://zedboard.org/sites/default/files/documentations/Installing-Board-Definition-Files_v1_0.pdf
    Assuming you installed a version of the BDF newer than 2015.4 it should work. What do you mean it doesn;t work? Does your PicoZed 7020 work with an Avnet Carrier Card?
    Josh
  • mathj
    0 mathj over 7 years ago in reply to jafoste4
    Thank you
    I was first looking for board definition files in Board Definition Files | Zedboard
    This seems to only include a subset of those found on the github that was linked in the guide.
