PicoZed Hardware Design Why DDR termination regulator part number is changed?
  • Subscribers 358 subscribers
  • Views 959 views
shahabamo
shahabamo over 7 years ago
I am designing a custom board based on picozed 7015/7030.
While looking at the revision history of picozed, I noticed that the DDR3 Termination regulator (U4) part number has been changed in revision D from TPS51206 to NCP51400.
I am curious to know the reason behind this decision. Is there any issue with TPS regulator? Can I use TPS51206 in my design?
regards.
  • jafoste4
    jafoste4 over 7 years ago +2 verified
    Hi, Feel free to use what you wish in your design. We we changed to the NCP51400 due to it being less expensive and it also being more line card friendly than the TpS51206. Both are adequate for the task…
  • jafoste4
    jafoste4 over 7 years ago in reply to shahabamo +2 suggested
    Hi Mah, Here is the current Avnet Line Card https://www.avnet.com/wps/wcm/connect/onesite/e08203c1-b5c7-4b1f-900e-d7ac0ec7d3df/americas-manufacturer-linecard-.pdf?M… -Josh
  • shahabamo
    shahabamo over 7 years ago in reply to jafoste4 +1
    Hi josh, Thank you for clarifying this. Just, May I ask that what do you mean by "Line Card Friendly"? regards.
  • jafoste4
    0 jafoste4 over 7 years ago
    Feel free to use what you wish in your design. We we changed to the NCP51400  due to it being less expensive and it also being more line card friendly than the TpS51206. Both are adequate for the task.
    -Josh
  • shahabamo
    0 shahabamo over 7 years ago in reply to jafoste4
    Hi josh,
    regards.
  • jafoste4
    0 jafoste4 over 7 years ago in reply to shahabamo
    Hi Mah,
    -Josh
