PicoZed Hardware Design PicoZed Z7030 Fail
  • Subscribers 356 subscribers
  • Views 658 views
PicoZed Z7030 Fail
cheshire_cat
cheshire_cat over 5 years ago
Hello.
We are using picozed z7030 in our researchs.
For some reason, two boards (of five) has now Flash programming initialization failed, when we try to reload them. Аnother three is still OK.
What can we do about it, does it some known problem?
Logs are in attachment.
P.S. Changing of boot mode switch SW1 doesn't change the warning that boot mode is QSPI and result of programming neither on failed modules, nor on good ones.
log-fail.txt.zip
log-ok.txt.zip
  • cstanton
    0 cstanton over 5 years ago
    Moved to PicoZed support forum from Feedback and Support.
  • drozwood90
    0 drozwood90 over 5 years ago
    Hi there,
    have you tried programming using JTAG directly?
    --Dan
