PicoZed Hardware Design PicoZed-7030 issues with 1Gbps throughput using PS ethernet
  • Subscribers 356 subscribers
  • Views 1204 views
  • picozed 7030
  • ethernet
  • vivado
simenett
simenett over 4 years ago
Hello! I'm working with a PicoZed using a Zynq-7030 SoC, and am having issues with getting anywhere near 1Gbps ethernet speeds. I have the ENET0 enabled with the MDIO, and is using MIO pins 16-27 (52-53 for MDIO). Under "Clock Configuration" I've set the ENET0 to request a frequency of 1000Mbps. Also using the ARM PL clock source. To test, I'm using a computer as a server and making the PicoZed act as a client. When looking at the packet loss per data throughput, It's clear that I start to experience large packet loss when reaching 260Mbps. Does anyone have any suggestions as to what may be the cause of this issue?
  • bhfletcher
    0 bhfletcher over 4 years ago
    Which PicoZed Carrier are you using? I know we saw some problems with our original PicoZed FMC Carrier, which is why we revised it to the V2.
    Bryan
