PicoZed Hardware Design PICOZED configuration memory
  • Subscribers 356 subscribers
  • Views 1247 views
jfioriglio
jfioriglio over 4 years ago
How do I readback program file from configuration memory on a PICOZED?
I am using Vivado tools.
  • mike.mandeville
    mike.mandeville over 4 years ago +1
    typically this isn't enabled because allowing you (anyone) to read back the contents of configuration memory would then allow that same person to buy one of your "widgets" read back all the configuration…
  • mike.mandeville
    typically this isn't enabled because allowing you (anyone) to read back the contents of configuration memory would then allow that same person to buy one of your "widgets" read back all the configuration contents and then use that file (those files) to re-create your hardware without the added cost of engineering work.
