PicoZed Hardware Design NVMe SSD connected to fpga drive is not detecting
  • Subscribers 355 subscribers
  • Views 1528 views
  • bare-metal
  • pci express
  • zynq 7000
  • petalinux
  • device tree configuration of picozed
  • picozed fmc carrier card
nithinsteffy
nithinsteffy over 2 years ago
Hi Team,
I've my new Picozed FMC Carrier Card Gen 2 equiped with Picozed 7015/7030 SOC on it.
I've successfully done booting through SD card with a prebuilt petalinux image. 2021.1
when i write command lsblk or lspci, it's not listing my WD Blue SN580 NVMe ssd connected to it.
Any solution for this?
Warm regards
NITHIN
  • nithinsteffy
    nithinsteffy over 2 years ago +1 verified
    Hi Team, Problem solved
  • nithinsteffy
    +1 nithinsteffy over 2 years ago
    Hi Team,
    Problem solvedimage
    0 shabaz over 2 years ago in reply to nithinsteffy
    What was the solution? (so that anyone else that hits this, can see the answer : )
  • nithinsteffy
    0 nithinsteffy over 2 years ago in reply to shabaz
    Hi Shabaz,
    The solution is pretty simple, I've done this using Windows, not in Linux.
    first of all we need to install Vivado 2022.1 and Vitis 2022.1
    Then clone  this repository to your desired directory.
    Then follow the steps in this link.
    It will automatically create a vivado project and a vitis workspace .
    then open vivado and open this project in vivado, then generate a bitstream for the block deign  already prepared
    then export the project including bitstream
    After that open the vitis workspace and run the project as GDB as mentioned in the link.
    you can see the output in putty connected to  fmc carrier card
    I've done this in picozed fmc carrier card equipped with picozed 7015 SOC.
    Please remember to put the switches in JTAG boot mode.
    That's all
    Regards
    NITHIN
