PicoZed SDR Software-Defined Radio External reference clock
  • Subscribers 357 subscribers
  • Views 1011 views
I am trying to drive the external reference clock (J1) on the FMC carrier card. I can change the mux inside the 9361 using the SPI interface but I am having trouble changing the clksel line from the Zynq GPIO that drives the mux external to the 9361. I have looked through the driver code but I don't see anything that references the clock select. Any advice is greatly appreciated.
-Kiel
  • mbrown
    0 mbrown over 10 years ago
    Hi Kiel,
    You can typically control AD9361 parameters in Linux from:
    /sys/bus/devices/iio:devices
    The mux is something extra that was added to the PicoZed SDR architecture and I don't see a corresponding parameter. I'll check and get back to you.
    /Matt
  • mbrown
    Okay, this is now enabled. The instructions for changing the clock select are posted here:
    https://wiki.analog.com/resources/eval/user-guides/pzsdr/carriers/fmc
    /Matt
