PicoZed SDR Software-Defined Radio Nothing displaying on HDMI Screen while booting the demo image by using picozed sdr 2x2: 7z035
  • Subscribers 358 subscribers
  • Views 1137 views
bhaghathpj
bhaghathpj over 9 years ago
Hi
 As per quick start manual, We tried to test picozedSDR 2x2 :7z035 board with the help of demo image. Booting is successfully done, but nothing displaying on the display.
We tried by using new downloaded image,latest version from "https://wiki.analog.com/resources/tools-software/linux-software/zynq_images", but still facing the same issue..
Also we gone through few forums, all the suggestions that they mentioned also followed..
Is anybody can help us, will be useful for us
Thanks and Regards
Bhaghath P J
  • bhaghathpj
    bhaghathpj over 9 years ago +1 verified
    hi The above mentioned issue is due to by using HDMI to VGA converter for interfacing VGA monitor. Instead of using the HDMI to VGA converter we used HDMI monitor itself Thanks for your valuable support…
  • mbrown
    0 mbrown over 9 years ago
    Hello Bhaghath P J,
    Please provide more debug info. Are you using the FMC Carrier Card? If so, what is the status of the following LEDs?
    DS1 : HDMI connected
    DS8 : FMC Carrier 5.0V regulator good
    DS3 - DS6 : GPIO LEDs
    D3 (SOM) : PG_MODULE (lights when SOM power supplies are good)
    D4 (SOM) :  FPGA_DONE (goes OFF when Zynq PL is configured)
    /Matt
  • bhaghathpj
    0 bhaghathpj over 9 years ago
    Hi
    DS1: ON
    DS8: ON
    DS3:DS6:Out of four  GPIO Leds, OnlyDS3 glowing  till the completion of booting process,once booting process over, it goes off.
    D3(SOM): ON
    D4(SOM): goes off once booting process over.
    Note: Am using HDMI to VGA converter for interfacing monitor with board.
    Bhaghath P J
  • mbrown
    Unfortunately we have not tested with any HDMI converters. Everything with the SOM diagnostics seem normal, so I'd suspect your converter is the problem.
    /Matt
  • bhaghathpj
    Hi
    Ok , I will try with the same without converter and update you the result once checked
  • bhaghathpj
    hi
    Thanks and regards
