PicoZed SDR Software-Defined Radio Error detect phy
  • Subscribers 359 subscribers
  • Views 735 views
Error detect phy
Hi!
I have a problem with Lab3 and was wondering if someone could help me please. I keep running in this error in Lab3/ Peripheral Test: "Error detect phy"
the full output when launchig that test is:
---Entering main---
Running ScuGicSelfTestExample() for ps7_scugic_0...
ScuGicSelfTestExample PASSED
ScuGic Interrupt Setup PASSED
Running Interrupt Test for ps7_ethernet_0...
Error detect phy
there is nothing happening afterwards.
i also tested this with the solution to lab 3 and there is the same error message and the exact same behaviour. Could someone please tell me waht is going on? is my board broken or is this another problem?
I'm running vivado2016.2;my board is picozed xc7z015.
milchprodukt
  • mbrown
    0 mbrown over 10 years ago
    What training are you refering to? Is this a Speedway course?
    You posted under PicoZed SDR forum, but the SOM you mentioned is not a PicoZed SDR SOM.
    /Mattt
    0 e14 Contributor over 10 years ago in reply to mbrown
    http://zedboard.org/support/design/4701/76
    Tutorial 03 Test Applications
  • jafoste4
    0 jafoste4 over 10 years ago
    Hi Wangy,
    You are using a PicoZed 7015, I will take care of this question on your other post you made in our Training section.
    http://zedboard.com/content/error-detect-phy-0
    Also please refrain from double posting questions. Thank you!
    --Josh
