PicoZed SDR Software-Defined Radio IRQ Vector number
  • Subscribers 358 subscribers
  • Views 468 views
IRQ Vector number
I have picozed sdr dev kit with carrier board.  I want to use one IRQ which is free.
May i know the from where i can get IRQ Vector id and which irq line i can access . I already referece 7000 SOC TRM but i can't get proper information.
  • jafoste4
    jafoste4 over 10 years ago +1 verified
    Hello Pareshchaudhary, Based on your other post, you want to bring in an external signal to interrupt the processor correct? If that is the case I would suggest you enable the PL-PS fabric interrupt withing…
  • jafoste4
    0 jafoste4 over 10 years ago
    Based on your other post, you want to bring in an external signal to interrupt the processor correct? If that is the case I would suggest you enable the PL-PS fabric interrupt withing your Zynq device and then route a signal from an external PL signal to the IRQ port on the Zynq PS IP block.
    --Josh
