PicoZed SDR Software-Defined Radio PicoZed 7035 SOM board definition files
  • Subscribers 358 subscribers
  • Views 1132 views
vinaygb
vinaygb over 9 years ago
Its been more than 6 months since the release of Picozed 7035 SOM and we don't see Board definition files for vivado yet.
In one of the forum topics, this issue was discussed and ADI TCL scripts are suggested as solution.
But there are no gudies/manuals for developing using those scripts.
Kindly provide Board definition files for Picozed 7035 SOM or provide user manuals for those scripts.
  • mbrown
    0 mbrown over 9 years ago
    Hello vinaygb,
    The ADI TCL scripts are the solution here. Please see the instructions in this post:
    http://picozed.org/content/how-do-i-rebuild-reference-design-hdl-project
    For more info have a look on ADI's wiki:
    https://wiki.analog.com/resources/fpga/docs/hdl
    For details on their repository structure:
    /Matt
    https://wiki.analog.com/resources/fpga/docs/git
  • vinaygb
    0 vinaygb over 9 years ago in reply to mbrown
    Thanks mbrown,
    I am trying to follow the steps in the links provided. But I am getting error when make command is run. I am trying to resolve that.
    But I want to know wha tis the end result of this make ?
    Will there be a menu listing during Vivado create project under Boards as PicoZed SDR 7035 SOM or  its just a project with pin constraints ?
    Vinay
  • vinaygb
    Thanks mbrown,
    I followed the steps as in the link.
    When make command is run following error is seen
    [~]> which vivado
    /cygdrive/f/Xilinx/Vivado/2015.2/bin/vivado
    [~]> cd f:
    [/cygdrive/f]> cd hdl-2015_r2
    [/cygdrive/f/hdl-2015_r2]> make pzsdr.ccbrk
    cd projects/pzsdr/ccbrk; make
    make[1]: Entering directory '/cygdrive/f/hdl-2015_r2/projects/pzsdr/ccbrk'
    make -C ../../../library/axi_ad9361
    make[2]: Entering directory '/cygdrive/f/hdl-2015_r2/library/axi_ad9361'
    rm -rf *.cache *.data *.xpr *.log component.xml *.jou xgui .Xil
    vivado -mode batch -source axi_ad9361_ip.tcl  >> axi_ad9361_ip.log 2>&1
    make[2]: *** [Makefile:73: axi_ad9361.xpr] Error 1
    make[2]: Leaving directory '/cygdrive/f/hdl-2015_r2/library/axi_ad9361'
    make[1]: *** [Makefile:73: lib] Error 2
    make[1]: Leaving directory '/cygdrive/f/hdl-2015_r2/projects/pzsdr/ccbrk'
    make: *** [Makefile:28: pzsdr.ccbrk] Error 2
    I tried to run make pzsdr.ccfmc and got same error.
    Please help in resolving this issue
  • mbrown
    Hello Vinay,
    Please post the contents of the axi_ad9361_ip.log. It may be that the scripts require Vivado 2015.2.1 (note the .1 patch).
    /Matt
  • vinaygb
    Thanks Matt,
    Compilation is successful after installing update 2015.2.1.
    Can you please guide me to the links for documentation of the vivado project which is generated after compilation and also some guides on how to integrate custom code into the generated vivado project.
    regards,
    Vinay
