PicoZed SDR Software-Defined Radio PicoZed SDR Connector placement and dimensioning
  • Subscribers 358 subscribers
  • Views 1018 views
We have some of the PicoZed SDRs on order and we need to come up with a board that will interface to it. When will a drawing be posted that shows connector placement, dimensioning and needed info to do the mechanical interface be available?
    Hi Arlen,
    The User Guide contains that info and will be published next week.  If you need the mechanical details more urgently, please let us know.
    Matt
    Matt-
    The User Guide (v 1.0)that we got at the PicoZedSDR seminar seems to have a problem with the illustrations showing the dimension information (Figures 14 and 15 in section 5), the image appears to be just a small corner of a larger document.  Also, Figure 16 shows dimensions to only three of the four micro headers.  Is there updated information available?
    Scott
  • mbrown
    0 mbrown over 10 years ago
    Yes, sorry about that.  Something with MS Word was broken.  Here are the 3 drawings.  I'm working on getting that 4th connector  dimension.  Hopefully by tomorrow.
  • mbrown
    0 mbrown over 10 years ago in reply to mbrown
    I see the pictures didn't publish in my last post for some reason.  We're working on a fix ...
  • mbrown
    ... it has this info you're after.  Thanks for your patience!
    /Matt
